I have read through a bunch of posts on this subject and I just wanted to get opinions.
I have a 2025 GSW with 111k on it so it's well past the warranty.
I have only noticed the leak in the past weeks because the passenger side floor is damp. Especially the rear passenger floor. And as I looked closer, I found water stains by the front pillars.
I tested the 4 drain holes and water does pour out the bottom. So they seem to be working.
So my question is the water leaking in from the drain pipes inside from the connection point? Or is there some other possible place it can leak from.
It's parked in my garage and I hardly open the sunroof so it's pretty clean in the channel.
Any thoughts on this are appreciated.
