Old May 8th, 2016, 05:35   #1
jjbendo
Default Rod knock
Hi Everyone!
On my 1996 Passat TDI 5-Sp, 185,000 miles I have what sounds like the beginning of a rod knock.
I am not driving the car. I plan to inspect the Rod bearings and replace them.
Besides having fresh rod bearing on hand what else will I need?
jjbendo is offline   Reply With Quote
Old May 8th, 2016, 07:37   #2
JETaah
Connecting rod bolts...they are one-time use.
You need to find out why you have a rod knock at 185K... i.e. oil pump, Faulty piston sprayers.
How do the cam/bearings look?
JETaah is online now   Reply With Quote
Old May 8th, 2016, 20:09   #3
vanbcguy
vanbcguy's Avatar
Dodgy injectors can make some really nasty noises which sound a lot like mechanical problems - the usual troubleshooting is to run the engine and loosen each injector line one by one - when you break the seal between the hardline and the injector it will no longer build enough pressure to pop. If the noise gives away with one injector in particular you know where to look.
Sent from my XT1097 using Tapatalk
My build thread: http://www.vwdiesel.net/forum/index.php?topic=32967.0
vanbcguy is offline   Reply With Quote
Old May 8th, 2016, 20:43   #4
john.jackson9213
TDI(s): 1996 B4V
Originally Posted by jjbendo View Post
Hi Everyone!
How about some plastigauge to measure your rod bearing clearances?
I pulled and measured rod bearing clearances on a 1Z engine with 285K miles last year. Rod bearings were still within factory specs. I simply replaced with new, check clearance, used new rod bolts (you have to use new bolts).
At 185K, if you need to replace the rod bearings, best you know what went wrong - or you may be doing the job again real soon. Or worse.
JJ
1996 B4V, Hella E-Codes, GLX leather, EuroTuning.cz 02A 6 speed conversion w/.71 5th and .588 6th gear, A4 shift linkage by Matt-98AHU. 11 mm pump by Oldpoopie. Now, GTC1549VZ turbo by Whitbread. TDtuning, 24 lbs. boost, 162 hp, 285 lb/ft tq. Smoke Free (9/18/15). Koni Yellows and Big Brake 5 lug conversion.
john.jackson9213 is offline   Reply With Quote
Old May 11th, 2016, 08:10   #5
jjbendo
Thanks everyone.
I will investigate and report back.
Old May 11th, 2016, 17:58   #6
ToddA1
Fuel Economy: Dismal
I'd check the injectors first. The cost of stretch bolts for the lower end, add up quickly.
-Todd
ToddA1 is offline   Reply With Quote
Old September 9th, 2019, 18:58   #7
antonio2001
https://youtu.be/Kcp3hohnXok
Does that sound like rod knock.?
antonio2001 is offline   Reply With Quote
Old September 9th, 2019, 20:04   #8
Mongler98
really hard to tell from inside. i hear it but does it change with RPM?
Old September 10th, 2019, 03:58   #9
JETaah
3 1/2 year old thread.
Old September 10th, 2019, 05:10   #10
Mongler98
Not the post I responded to
Old September 11th, 2019, 17:04   #11
antonio2001
Kind of.. its werid seems to do it a few seconds after i let off throttle then stops. And yeah seems to generally folow rpms
Old September 11th, 2019, 17:55   #12
Mongler98
check under the valve cover for any spider cracks or any odd wear on either the cam and or the lifters (directly under the cam. if it looks nice and cleanly worn its fine
ever run low or out of oil? check oil pressure with a gauge
Old September 11th, 2019, 20:50   #13
antonio2001
Lifters are new . (60 000km) from INA but with a used cam from another engine. But i doubt its that. Oil pressure is good. 22 psi idle hot. Goes up nice and fast with throttle. Any other ideas off the hat?
Old September 11th, 2019, 20:55   #14
Mongler98
Used cam with new lifters? I bet you that's the problem . You need them both to be new or resurfaced. You will kill lifters and a cam if you mix match them even of they are good. Did you at least run zink for a few hundred miles?
Also where exactly did you get the liftes, there are bad ones and good ones. Frank06 is who you want to talk about lifters. There are threads about this. Who did the work.
Old September 12th, 2019, 05:59   #15
antonio2001
Theyre ina lifters. Good stuff. I did the work. And i inspected under valve cover this mor i g. Clean as hell
Knock knock sound in the driver wheel well while braking, checked everything. guillaumeber VW MKIV-A4 TDIs (VE and PD) 14 July 9th, 2017 08:36
Rod knock? Loud noise!? Help drftr915 TDI 101 53 May 4th, 2016 09:17
Knock, Knock, Knocking On Heavens TDI hanother VW MKIV-A4 TDIs (VE and PD) 15 September 22nd, 2013 12:09
nozzles causing rod knock sound? 011852 VW MKIV-A4 TDIs (VE and PD) 22 October 3rd, 2005 09:49
nozzles causing rod knock sound? 011852 Ontario 2 September 29th, 2005 05:16
Page generated in 0.17156 seconds with 12 queries
[Output: 118.87 Kb. compressed to 98.65 Kb. by saving 20.22 Kb. (17.01%)]
