djmiller
2005 VW Jetta GLS TDI (mk4) $4,000
1.9pd, BEW engine
5 Spd manual
500,000 miles (cool!)
I upgraded to a bigger more comfortable car
Feel free to ask any questions, I'll answer to the best of my ability!
1 owner (me) I have spreadsheets for maintenance and repairs from new, and fuel MPG for the last 250,000 miles. Oil and filter every 10,000 miles, fuel filter every 20,000 miles. Head gasket changed at 400,000 miles with UK PD150 headbolts.
Just put $1700 of parts in it. New Battery, Tires, Turbo (S7), new Kerma tune, timing belt, tensioner, idler pulley, water pump (diesel geek kit) new air/fuel/cabin filters. Oil and filter just changed, new antifreeze,
Has South Bend stage 2 clutch, solid flywheel
New front struts and springs
Panzer plate, with aluminum side panels
Boost/EGT Guage
TDIheater
VW all weather floor mats (rubber)
Trailer hitch and wiring adapter
Wired for stereo amplifier
3” 55w D2S HID projector headlights with fog lights (35w) with UK headlight switch (w/front and rear fog lights) Rear fog lights are installed and work
Extra high beam headlights installed in grill
LED reverse lights (extra)
Comes with Q-loader($600) (kermatdi), Vag-com cable (HEX-CAN $200 before they limited it to 3 vehicles), extra sealed beam bulbs for high beams($150), Bentley service manual($80), specialty tools for timing belt replacement, crankshaft position sensor($34), extra lug nut lock tool (1 for car, 1 for tool box), Door lock assy, Fan controller(OEM), oil filter, extra front struts (new), sway bar bushings, OEM headlight switch, wire pigtails (OEM), hazard switch
[/URL] [/IMG]
1.9pd, BEW engine
5 Spd manual
Boost/EGT Guage
TDIheater
