lanorg
Anyone know what psi the alh tdi coolant operates at?
Been trying to diagnose coolant coming out of the jeep rad cap (18psi it will hold) as it reaches operating temps 86-88*C and up. Flushed the heater core and rad, no blockages. Alh out of a beetle and mated to the tj driveline runs well but struggles to supply hot cabin heat in the winter.
Alh operates just as it does in my jetta wagon with warm up but the coolant keeps leaking out of the rad. Im guessing the tdi coolant system runs at a much higher pressure. Can anyone chime in? The expansion tank holds pressure just fine. Im also thinking the leaking doesnt allow for pressure to hold and temps to maintain a hot op temp.
92*C thermo stat is brand new
Coolant lines are clear of debris
50/50 g12 and deionized water has less than 700km on it
