joewrench
I've had my tdi Toyota running for a few years.
So here's the basics.
ALH engine
vnt17 hybrid
.280 injectors
11mm pump
Fx300 10" clutch masters clutch
V6 trans
Custom made adapter plate by local machine shop
Malone tuning
So I just upgraded to the r150 trans and got it all out together but the starter didn't engage. Did some research and figured out the v6 ring gear has 120 teeth and the 4cyl. flywheel I'm using has 115. I haven't found a flywheel with 6 bolts that has 120 teeth. Only thing I found is grinding the starter to move it closer. Which I don't really like.
http://forums.tdiclub.com/showpost.php?p=3734795&postcount=17
But I want to get it running again after being down for over a month so I just did it to get me going. What are the others doing for flywheel with the r150 trans??
ALH engine
vnt17 hybrid
.280 injectors
11mm pump
V6 trans
Malone tuning
