dslemaire
I have a strange problem in that my 96 passat has had the engine die on 2 occasions, both times about 3 miles from my house on the first drive of the day.
The first time I noticed that there was some air in my fuel line going to the filter. (I'm running biodiesel and put in a prefilter with some clear fuel line) It seemed that a line was slightly loose and I tightened it up. It ran fine for over 100 miles then this morning it suddenly quit again. But this time the fuel lines had no air in them, so I don't think it's a filtering issue and if it was I don't think it would start up and run perfectly normal at highway speeds.
It seems to be something electrical, but there's no CEL and nothing else obvious.
When it dies, it's been when I'm driving down the road about 30 mph and the engine suddenly stops, oil pressure light is flashing, I pull over and it won't restart. After about 5 minutes of waiting. It restarted and ran fine, for the next couple drives of over 150 miles of highway driving.
I replaced the 109 relay about 2 years ago with the grey one as a preventive measure, and I'm thinking maybe I should try putting the old one that worked back in for a while or get a new one?
Any suggestions?
Any suggestions?
