E-Code Headlights on '01 Jetta
dok
Los Angeles
'96 B4V
Installed a pair of e-codes today. Car came w/ european light switch(front/rear fog lights), Checked all fuses, but fog lights will not turn on. Any suggestions?:confused:
David
Ed's TDI
Victoria, BC, Canada
2001 Bora and 2016 Touareg
As 'Dorf is eluding to, you need a foglight wiring harness and need to run it from the headlights to the headlight switch, otherwise they're just pretty looking and not much use! :D
compu_85
Gadget Guy
La Conner, WA
... None :S
IE, the wireing between the headlight switch, and the front and rear fogs isn't preinstalled on your car.
-Jason
dok
Los Angeles
'96 B4V
Sure are pretty looking;), but I'll buy the harness and make them useful. Thanks for help.
David
Joe_Meehan
Ohio USA
NB TDI, 2002.5, Silver
David
Are you pulling out the switch? Does the fog lamp come on on the switch? I believe you also need to have at least the parking lights to get the Fogs on.
Ed's TDI
Judging by the original poster's reply, he hasn't purchased or installed a foglight wiring harness. Since this is the case, it wouldn't matter if he pulled the switch out into the foglight position or not, the foglights wouldn't magically turn on without any wiring.
Paramedick, I agree that MM's wiring harness is a pretty decent product. Just goes to show that even us Canucks can do something right! :D
dok
Los Angeles
'96 B4V
Foglight wiring kit was in the mail when I arrived home from work. Installed by flashlight without too much trouble:rolleyes: . What a difference they make. Rear fog kit in tomorrow.:rolleyes:
