Old December 17th, 2014, 11:38   #1
redcorradoguy
Default Terrible vibration/noise/loss of power--Lifter failure
I purchased an '02 TDI New Beetle with a broken tbelt for a pretty decent deal. I was towing it home with my '02 TDI Golf, Beetle was on a dolly.
The car pulled just fine most of the way, but as I was going up a hill I noticed a loss of power and the engine sounded different. When I pushed the clutch, I fully expected the motor to die (that the momentum was the only thing keeping it "running") however it actually didn't die. But it sounded terrible.
I may have seen a little smoke coming from under the hood when I initially stopped but I'm not 100% sure, and there weren't plumes or anything when I opened the hood and restarted the motor. The engine runs, but vibrates pretty badly. There is an "exhausty" noise but part of the noises may well be part of the engine contacting the Panzer Plate due to the vibrations.
There is a significant lack of power too. Some have asked about motor mounts being an issue, but I can't think of how that would really affect the power?
The check engine light never came on. I do have the VAGCOM stuff so I'll still check for any codes just in case.
There is nothing obviously broken from what I could see on the side of the road. Anyone have any other ideas?
redcorradoguy is offline   Reply With Quote
Old December 17th, 2014, 12:02   #2
You may have broken a motor mount, and that may have caused a intercooler hose to disconnect. So you get a vibrating engine (broken mount) and loud noise from both vibration against something (subframe, skid plate) and no boost with the loud engine sound that comes with.
Check your engine mounts for damage. Also grab the valve cover and see how much the engine moves. Your dogbone may be what broke. Look at the intercooler hoses (especially the one from the turbo to the IC) and see if any are disconnected.
2002 Jetta wagon, 362K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 257K; 2011 335d, 56K; 2015 Golf Sportwagen, 8K. Principal, http://www.idparts.com
Old December 17th, 2014, 18:27   #3
CopaMundial
Where did you find a hill in Kansas?
I would troubleshoot the low power symptom first. Since it happened under load then a boost pipe popping loose is a prime candidate.
CopaMundial is offline   Reply With Quote
Old December 17th, 2014, 19:46   #4
redcorradoguy
Welp, after wasting time with things like taking the Panzer plate off and looking for broken motor mounts and loose boost tubes, I found my problem!
One of my lifters has come apart! I have no idea at this point if the valve itself is damaged or not. (Well, I can only assume it is damaged. I don't know if it broke off and caused damage in the cylinder or not.)
As an early step in trying to diagnose the problem, I did crack each injector line with the engine running, and each one did seem to affect the engine some. So maybe there is hope that the valve was opening and closing a little bit.
Crap. Time to get cracking on the New Beetle, and decide what the heck to do with this one.
Old December 17th, 2014, 19:50   #5
redcorradoguy
The car has 286,000 miles on it, and is starting to get a little rough around the edges. The car was rear ended and totaled two years ago, so I've always imagined I'd put money toward keeping it safe and going down the road but not worry about upgrades, etc. And just keep it going until something really bad happened. I guess I have to decide if this is the really bad thing. I would have preferred the really bad thing be just about anything besides the engine crapping out-I could use it in something else!
Despite having been hit and getting a little banged up otherwise, it ran and drove great before this. It steered well, the transmission and clutch seemed to be in fine shape, etc. It is comfortable to drive. And despite all its warts, I really like(d?) driving it.
Old December 17th, 2014, 20:24   #6
redcorradoguy
Also, I would like thoughts on whether towing the New Beetle was a factor in this damage, or if it was just a coincidence? (Or maybe caused it to happen a little quicker than it would have otherwise, but it would have still happened pretty soon?)
I had used the Golf to tow my camper Bus to Nebraska and back a year ago without any issues.
Old December 17th, 2014, 20:33   #7
CopaMundial
Coincidence IMO.
Old December 18th, 2014, 03:47   #8
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
The bore for the lifter is likely damaged. If so then the head needs to come off.
FYI... recently saw two "random" lifter/cam failures on ALH. One was questionable whether the head needed to come off, customer decided to have us pull the head due to "minor wear on the valve stem". The other the lifter stuck downward due to bore wear and the valve bent. We fixed them both.
Richard. ASE Certified Master Auto-Technician with L1 Advanced Engine Diagnostic Rating. ATRA Certified in Rebuilding, Diagnosing & Installing Transmissions.
LOOK AT MY YOUTUBE CHANNEL -->
https://www.youtube.com/user/CoolAirVw/
Now offering Malone Tunes!..............http://www.kansascitytdi.com/
CoolAirVw is offline   Reply With Quote
HELP: HUGE pothole caused massive vibration, loud engine noise, & loss of power TDI_Lee VW MKIV-A4 TDIs (VE and PD) 11 December 22nd, 2014 00:03
1.9 Tdi vibration power loss A4.power TDI 101 10 May 25th, 2014 23:47
mk4 PD jetta vibration and loss of power witchcraftz TDI 101 12 June 26th, 2012 16:47
surging/vibration and power loss 04SlvrJetta TDI 101 6 October 19th, 2009 14:24
First a whistle.Then loss of power and Noise BrokenDown VW MKIII-A3/B4 TDIs 7 July 15th, 2004 04:50
Page generated in 0.15021 seconds with 11 queries
[Output: 87.27 Kb. compressed to 75.17 Kb. by saving 12.11 Kb. (13.87%)]
