AV8RLEO
Hi All,
Couple questions for those in the know...
So I've spent some time searching through the forums and can't find what I am looking for (or I'm just lousy at searching).
2003 TDi Jetta with 5 speed Manual...
Currently in my Jetta I have a randomly occurring "blinker sound." Now I say blinker sound because the blinker is making the blinking sound at random when I'm driving but none of the inside indicator lights nor outside actual lights are coming on. I've checked both during the day and at night (to make sure it isn't a dim flash) and there are no actual bulbs coming on, just the annoying blinking sound inside the car... When you turn on the turn signal or the Hazard Lights the lights both inside and out (and the sound) work completely normally.
So... Is the relay shot? Is the multi-function switch shot? Is it something else? What do you all think?
2nd question... It's looking like I'll be due for another timing belt project around August of 2015. I did my last one in August of 2011 with 162,700 on it and it looks like I'm going to hit the 90,000 mile mark (on a high mileage kit) about August '15.
The question is what else should I really look at doing as the car will have just over 250,000 miles at that point and I'd like to see it go at least 100,000 more.
I figure Engine Mounts are a must, and I plan on doing the high mileage timing belt kit again but what else? Just did a complete suspension overhaul this past February including new hubs and bearings. I've changed out transmission fluid, did glow plugs and harness at the last timing belt, seams to start fine (little smoky), my oil analysis looks good. I'm tempted to pull the intake, have it thoroughly cleaned and then do the EGR block or Delete...
Any other suggestions? I can't afford to drop thousands but want to keep it running well....
Thanks!
Thanks!
