Old October 9th, 2010, 18:03   #1
Brother James
Fuel Economy: 46mpg
Default intermittent engine noise/vibration
Hi all, my tdi is an 05 pd with 133000 miles on it. I've had it for 2 1/2 years and have but 75,000 miles on it. Oil changes every 10k, mostly 10W30. The problem is this; suddenly and without warning when starting to drive from a standing stop the car apruptly sounded as though the exhaust at the cat just let go. Really loud, right under my seat, the vibrations were moving stuff around on the dash. I shut the car off and looked under expecting to see the all too familar exhaust hanging loose and broken only to find all as it should be. Next got back in, pulled over to the side,and this time left the car running so as to lsten for the leak. It was quieter outside the car, under the hood did sound louder and rougher. I shut it down again, waited , check the oil, down 1qt. (but I knew that, I had planned to change the oil next weekend) , added 1qt. of oil to make sure the dip stick was reading right, it was, it was now at full. I decided to drive on, its now about an hour nice the onset, and the car is sounding less bad. Drove for 2 mi. stoped, waited, checked everthing one can check while on the side of the road, and then drove on. The noise and vibration were gone, as if it never happened.
I drove around town the next day, no problems but I had a feeling that something just isn't right. I drove 45 min. to work , all still alright, untill the last 1/4 mile, a hard right up a steep hill in first gear, and there it was again that phantom noise, back again. It was gone when I check 15 min. later. Any thoughts any one ?
Brother James is offline   Reply With Quote
Old October 9th, 2010, 19:08   #2
Brother James
Fuel Economy: 46mpg
Some thoughts as to possible causes are starter moter not disengageing, or cam shaft failure issuses, gremlins.
Old October 11th, 2010, 10:54   #3
Brother James
Fuel Economy: 46mpg
Problem solved.
Old October 11th, 2010, 13:36   #4
JB05
Fuel Economy: 43/41/40
I'll prevent this from becoming a one-man thread; so please tell us what the problem was. Did your skid plate come loose, perhaps?
JB05 is offline   Reply With Quote
Old October 15th, 2010, 17:29   #5
Fullhouse
Fullhouse's Avatar
TDI(s): Golf 4 ARL
And why do you mostly use 10w30 ?
From AGR comfortline to:
ARL with a lot of mods
Fullhouse is offline   Reply With Quote
Old October 15th, 2010, 17:38   #6
jonferns
jonferns's Avatar
TDI(s): '15 Golf
Please post what you found the problem to be, and how you fixed it. Thanks
'15 Golf S TDI - 68k, DSG
'12 JSW TDI - 99k, 6MT Buyback complete!
'06 Jetta TDI - 150k, DSG, Package 2, Malone Stage 1, RCD510 Retrofit
'06 Jetta TDI - 220k, DSG
jonferns is offline   Reply With Quote
Old October 16th, 2010, 16:23   #7
Brother James
Fuel Economy: 46mpg
Hi I've been away for alittle while so wasn't keeping up with posts. A rock had gotten weadged between the black bracket on the dog bone mount and my DG skid pl8. You would not believe the noise that can make! I panicked and feared the dreaded can failure had come to claim my tdi.
And as for oil; yes 5W30, it's what is offered most in oil change kits from online sources, at least the ones I'm familiar with; but never again.
thanks
Page generated in 0.11980 seconds with 10 queries
[Output: 74.28 Kb. compressed to 64.08 Kb. by saving 10.20 Kb. (13.73%)]
