rfriend
I have a 2004 Golf with ~15k miles. The ECU reflash was done last fall and at the same time the ground wire(s) were updated. The fuel pupm is not within the recall numbers and does not appear to be leaking.
I have a euroswitch and ecode headlights installed, although the fogs have not been wired yet.
There is about 1/2 tank of fuel from the same station I usually use and has Power Service added.
The engine has never failed to start on the first try until yesterday morning. It would not fire on the first attempt. On the second attempt I cranked for 10-15 seconds and the oil indicator began flashing. On the third attempt after about 10 seconds of cranking I gave it a little accelerator and it slowly began to fire. On each try I wated for the glow plug lamp to go out. It started fine the rest of the day. The problem repeated this morning.
The temp is about 45 F and it has been raining for the last 4 days.
Anyone have any ideas?
I am concerned as I have to drive to Maryland tomorrow and do not want to get srtanded.
