VCDS VAG-COM Locator
Nuje
Island near Vancouver
Comox Valley on Vancouver Island in BC, Canada.
Have most of the good toys (including VDS-PRO to enable hatch-opening in sync with doors, and window roll-down with key fob). :)
NewTdi
NorCal
2003 Bora, Reflex Silver
I was just driving through the 909 this morning and had my laptop and cable with me. I am going back to AZ next week if you need help. Send me a PM if that’s the case.
OLDFATMAN
03 JETTA
One Snap-On Quantus OBDII scanner in our shop and 4 minutes 39 seconds and we have success at a 4.2 injector quantity. It ran all pids successfully. It’s an option and likely found more abundantly at independent shops
1854sailor
Resident Curmudgeon
Westerly, RI
We're in the process of moving from Baltimore, MD to Westerly, RI, spending most of our time in RI. I have VCDS HEX-NET if anyone needs to solve a problem. Will scan for beer...
JohnTF
St. Paul , MN.
2003 Jetta 1.9 TDI ALH A.T. Wagon
I have a KII-USB , beer sounds good ;)
Maybe lunch ?
St. Paul , MN
Had to edit - bear could be trouble
DivineChaos
Minnesota
mk6 jetta sportwagen tdi
I've got a kII and a hex-net. Food and company. Hibbing MN area. Pat for fuel and I'll go up to 100 miles also have an obdeleven that's always in my car.
Zak99b5
Albany NY
2003 Jetta TDI
Looking for someone with VCDS or similar in the Albany NY area. I did the timing belt and need to fine tune the injection pump.
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
Try local car enthusiasts groups, the gassers use the same device.
Our map seems broken, vortex has a working thing here
Of course you only need a compatible OBDII device that can read Measuring Block 000, Field 2.
Nevada_TDI
Reno, sort of...
2001 Jetta TDI
I live in Carson City, Nevada, 30 or so minutes from both Reno and South Lake Tahoe. I have USB HEX-CAN. All years from 1999 to last week. Email: souffle at ymail dot com
Mozambiquer
Versailles Missouri
I am in Versailles Missouri and have Vag-com hex-can and also the free vds-pro/vag-tacho that gmenous made.
rohls
CA
MK4 golf
Hi,
I'm in Santa Rosa, CA 95409. I just did a timing belt on my 2001 Golf TDI ALH and am looking for help fine tuning the timing, etc. with VAGCOM / VCDS. I contacted the one member nearby via the Map, but no reply yet. Granted it was just minutes ago. Thanks for your help!
Abacus
That helpful B4 guy
Only the B4V left
Moved to the Prescott, Arizona area, HEX-CAN-USB, so I can scan most everything up to 2019 or so. I also have the 2x2 adapter to scan the 1990-1995 cars.
tjgalvin
Asheville, NC
2000 Jetta RIP (Camshaft failed at 406k miles) 2004 Passat TDI, reluctantly sold, 2005.5 Jetta TDI 115k, 2003 Jetta TDI 315k
I need a little help here in Asheville to pair a new key chip to a 2006 Jetta TDI. I have a primitive OBD tool and I am not comfortable trying to write to the computer memory with it. Thanks.
Please send a PM if you can help.
Tim
1854sailor
Resident Curmudgeon
Westerly, RI
You need VAGTacho, not VCDS to match keys to the immobilizer, but I'm pretty sure that the 2006 cars have Immobilizer 4, which can only be programmed by a dealer...
Nuje
The "early" 2006 were still BEW / Mk4, whereas the later ones got the big upgrade to Mk5 and all of its "wonders".
Maybe @tjgalvin will be on the fortunate end of things with his Mk4 - in which case you need VAG-TACHO (or this software tool) to pull the cluster's PIN, then you can program the key with VCDS.
jokila
Houston, Texas
2003 Jetta GLS, Manual
I thought it was 2005 on the model break. Early 2005 were mk4, later 2005s were mk5.
Nuje
jokila
Houston, Texas
You may be right there. I always mix it up because I know that here in Canada, you could still buy a 2006 Jetta wagon (and only as a TDI, IIRC) in the Mk4 body style.
Wagon are different in that they were all made in Germany for the North American market and thus were handled differently than the sedans.
GrapplingDMC
Elma WA
1997 Passat Wagon (going into a 1995 Suzuki Sidekick)
Mozambiquer
Versailles Missouri
Ok this is going to show how little I know & that I am a total noob. I am about to pull my TDI and start my project and want to do it right, I know the ERG thing needs to go but need as Vagcom. I bought a 2021 Foxwell NT510, (here is a link to where I bought it:
will this do what I need for the EGR delete? If not, where do I find someone near Olympia WA?
Which year car? Most cars you need to actually tune it to do an EGR delete, with the exception of an ALH, which you can turn down with Vagcom.
