Stealth TDI
Pre-Forum Veteran Member
Hi,
Someone showed me some small batteries that lighten up the front end during autocross events:
Less weight up front leads to less understeer. The battery seemed good for him because he has a 2-liter. However, I'm doubtful that such a battery is practical for turning over a high compression engine like the TDI.
What do you think is the minimum amount of CCAs a battery should have? Better yet, what's the minimum you'd put in a TDI during the racing season (warm weather) and what's the minimum CCA you'd use for year 'round use?
Thanks,
Scott
Thanks,
Scott
