PRY4SNO
Driving home today (steady, on cruise control) and out of nowhere lost power, with the Workshop light on with the GP light flashing. Thought it was odd, so used my OBDeleven to check codes:
P20D8 - Exhaust aftertreatment fuel supply control
P0299 - Turbocharger underboost (upper limit exceeded)
Then, after I cycled the ignition a MIL came up with a new code:
P1592 - Altitude sensor signal/charge air pressure sensor (implausible ratio)
Limped home since I was only a few kms away. Checked the N75 vac tubing by eye and hand, no obvious splits that I can see, but the engine wasn't running by then. Ran a log of the engine controller with my VCDS and I'll post that in a quote below.
What measuring blocks, if any, should I log before I take in the car for warranty service?
Other relevant thoughts, links?
Thanks!
Thanks!
Address 01: Engine Labels: 03L-906-022-CBE.clb
Control Module Part Number: 03L 997 030 L HW: 03L 906 022 TS
Component and/or Version: R4 2.0l TDI G001SG 9983
Software Coding: 0350072
Work Shop Code: WSC 03421 003 1048576
VCID: 377DFF8F462340F224-8062
4 Faults Found:
008408 - Exhaust Re-Treatment Post-Injection
P20D8 - 000 - Control Limit Reached - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 291111 km
Time Indication: 0
Date: 2031.14.30
Time: 17:42:55
Freeze Frame:
RPM: 1932 /min
Speed: 115.0 km/h
Torque: 105.0 Nm
(no units): 1.00
(no units): 1.01
Temperature: 354.0°C
Load: 20.0 %
000665 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 291501 km
Time Indication: 0
Date: 2031.14.31
Time: 18:08:40
Freeze Frame:
RPM: 2139 /min
Speed: 83.0 km/h
Load: 59.6 %
Pressure: 2178.0 mbar
Pressure: 1331.0 mbar
Lambda: 89.2 %
Lambda: 88.4 %
P0299 - 001 - Control Range Not Reached
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 291501 km
Time Indication: 0
Date: 2031.14.31
Time: 18:08:40
Freeze Frame:
RPM: 2139 /min
Speed: 83.0 km/h
Load: 59.6 %
Lambda: 89.2 %
Lambda: 88.4 %
005522 - Altitude Sensor / Boost Pressure Sensor
P1592 - 000 - Implausible Correlation - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 291505 km
Time Indication: 0
Date: 2031.14.31
Time: 18:11:36
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 13.00 V
Pressure: 931.7 mbar
Temperature: -15.3°C
(no units): 5.0
