I have a '99.5 Jetta GL with a 2001 engine (long story). When the engine was replaced in the spring of '07, the mechanic replacing the engine recommended installing a new thermostat. He used a NAPA thermostat. About 6 months after the engine replacement, my engine temperature started bouncing around. I replaced the coolant temperature sensor (CTS) with a new blue one from TDIParts.com. The temperature ran steady at the 190 deg. mark until about a month ago. The temperature began topping out at one hash mark before the 190 deg. mark. It consistently topped out at this same point and after doing some forum searches, I felt confident it was the thermostat. I replaced the thermostat with a Wahler from TDIParts.com. Now the temperature is consistently running at two hash marks below the 190 deg. mark or the first hash mark past the 3 close ones. I measured the termperature in the coolant reservoir with a meat QA meat thermometer and it read 182 deg after a 10 mile drive. The consistent temperature reading makes me think it is not the CTS. Any opinions, suggestions, etc.? By the way, my fuel economy has dropped about 3 mpg since the operating temperature change.
