deecee
I will put a link to craigslist ad for pictures.
I no longer have any VW's and am clearing out my parts that I have laying around.
I will ship smaller things at buyers expense.
TDI Injectors and Fuel lines - I picked these up from a totaled car so i don't know the history or what nozzles are on them. - $110
TDI Injectors No Fuel lines - Again I picked these up from a wreck and don't know the history. No fuel lines on this set - SOLD
TDI Injector Hold Down Clamps - I have 12, all but 3 have the bolt and washer. $10 each or all for $80
MK 4 GLI Rear Seat - These are in good condition, a couple of tiny holes hard to find, and the release clip is broken, but easily fixed with a replacement. - $80
20mm Aluminum Wheel Spacers - 5x100 and another unknown bolt pattern. 20mm and in good condition. - $40
MK4 Parking Brake Cables - These fit Mk4 Golf and Jettas I THINK, Check part number 1J0 609 721E - $20
2 Door Golf Door Inserts, Cleaned up ready to recover. I am nearly sure these are the front ones. $30
96-97 B4 Passat TDI Intercooler pipework $80
One use Stretch bolts - Mk4 Tdi Engine Mount set x 2 SETS ARE NOT COMPLETE 2 BOLTS ARE MISSING FROM EACH SET, No time to go through to see which one. $10
Mk4 Tdi Vacuum pump and hose - $10
Unknown Buschings x 2 $5
Mk4 Golf/Jetta Turnlight/wiper/cruise control switch - $10
N75 Valve, at least i think it is? - $15
B4 Passat Tdi CCV pipe and filter - $25
B4 Passat Tdi Lower control arms - $30
New Beetle Tdi Intercooler - $40
VR6 B4 Passat Air box and MAF - $20
Mk4 Golf Trunk, dark blue paint - $40
Mk4 Golf 2 Door Window Glass, drivers side, - $10
I can bring to Asheville if needed and will ship smaller items.
https://asheville.craigslist.org/pts/d/vw-used-parts-clearout-tdi/6599737170.html
