Old September 4th, 2019, 17:14   #1
rsfeller
TDI(s): 1996 Passat
Fuel Economy: 46.7
Default AC geniuses please step up...got a weird one.
Thought I had the common compressor solenoid on our 2011 JSW that runs the Sanden 16 model. Ordered a new solenoid from a well rated seller and had my reluctant local shop suck, swap and blow the freon back in.
My AC went from working 90% of the time to 100% dead. I really thought I had the common solenoid failure that can conk out at low RPM or high RPM but works pretty darn well most of the time. Accepted the fact I prob got a bad compressor and tech said it had the same pressure readings on high and low side, so...
Was saving up for a full DIY rebuild of the system.
Forward to three weeks later after all the 94F weather is over and I'm on the free way today doing 65MPH with the windows and sunroof open and all of a sudden my feet start freezing. I look at the HVAC system and the AC button is OFF...100% OFF. I clearly have AC coming from vents on a 80F day. I turn the button on and for the next hour I have AC. No issues at low or high speed, idle ect. Drove home and put inferred gun on it and it's shooting 42.5F out the vent at 80F ambient (60%).
*** is going on with the AC running with the switch off?
I'll update more tomorrow to see if this was a fluke or resurrection from something clogged (unreleased to previous issue).
I can add that it seemed that often the fan speed has an over drive when on 3 or 4 that will increase RPM/speed and allow AC to kick on in the past. I even got crazy for a moment when I thought turning on recirculation would engage AC...so maybe I'm dealing with a wiring/computer issue here rather then hardware?
Also, and VCDS testing I can do?
rsfeller is offline   Reply With Quote
Old September 5th, 2019, 04:51   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
OBD works, start there. The Climate has the ability to store and display DTCs, has observable data, and even some other things, just like any other module in the car.
oilhammer
www.cardocautomotive.com
Old September 5th, 2019, 08:42   #3
JELLOWSUBMARINE
JELLOWSUBMARINE's Avatar
Thats interesting. When my typical RCV related issue acted up the fan speed had a mind of its own. Air flow would choke down (seemed like internal door flap closed??). This was only when not cooling properly as I recall. Please post the DTCs if your able. Ive been out of the a/c feild for awhile and am amazed by the a/c tech improvement.
JELLOWSUBMARINE is offline   Reply With Quote
Video: Polar FIS Step-by-step Install - 2014 JSW TDI aCab VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 22 April 25th, 2019 20:10
DrVolks.com installs a Bilstein Sport and H&R Spring combo step by step video CNGVW Upgrades (non TDI Engine related) 0 May 12th, 2016 05:22
Oklahoma City TDI geniuses ??!?! Scot1969 VW MKIV-A4 TDIs (VE and PD) 1 March 31st, 2008 00:12
Dairy employees are geniuses Brian24 Non VW Group Diesels 10 May 6th, 2004 15:05
anyone interested in posting a step by step for intake manifold removal/cleanign? gboss VW MKIV-A4 TDIs (VE and PD) 2 March 7th, 2002 07:02
Page generated in 0.14794 seconds with 11 queries
[Output: 61.27 Kb. compressed to 55.81 Kb. by saving 5.46 Kb. (8.91%)]
