Old April 26th, 2007, 20:27   #1
Keith_J
Keith_J's Avatar
Fuel Economy: 38 MPG @ 80 MPH with 2 bikes on top. 52 MPG @ 60 MPH slick
Default Interesting ring wear observation
In the process of replacing piston/rod #1 due to failed tappet causing valve-piston contact, I am replacing the rings in the rest.
Measuring the ring grooves with the old rings had me worried as a 0.008" feeler gauge easily entered...so I pulled that ring and compared it with a new one. The used ring was indeed 0.003" thinner yet only showed 0.002" had worn from the face that contacts the bore.
Measuring the ring groove with calipers indicates less than 0.001" of wear. Pistons can be reused, at least the ones that didn't contact the valves.
Keith_J is offline   Reply With Quote
Page generated in 0.12432 seconds with 10 queries
[Output: 42.88 Kb. compressed to 40.23 Kb. by saving 2.65 Kb. (6.19%)]
