banshee365
Hey fellas. I tried resuming an old thread I had made about this '06 that I maintain and repair for family but there were no more replies even after a bump: http://forums.tdiclub.com/showthread.php?t=419308
So, I'll give a new thread a shot as I spent some time diagnosing this car today. It was running perfectly then parked for 4-5 day's. Upon restarting the car all of a sudden will hardly run, and often won't run. I was first told it won't go over a crawl. When I got to it it wouldn't hardly run and typically just shuts right back off after it fires a few dozen revolutions. This much I can tell you:
The first start for diagnosis today the car ran great for about 3 seconds. The injector deviations were all less than 30. Then the thing went to misfiring and abruptly shutting off. After that I can't keep the car running under any condition. Every time the engine shuts down you have to cycle the key which means I have to reboot the module in VCDS and load the 3 measuring blocks I was looking at. The car will usually run like garbage for one second then shuts down. I'm not able to collect any data to help point me in the right direction as the refresh rate on VCDS doesn't allow me to use hardly any of the data I'm looking for.
The car went from running great to all of a sudden acting like this so I first thought about a harness issue. It very may well have a harness issue but I sure don't see any damage on the harness so far.
I know there are many guys on here with more experience than me on the BRM and I could sure use a few ideas tossed around on where to go next. The battery is dead now so I'm charging over night.
- It was not misfueled.
- The lift pump provides ample volume.
- The cam timing is dead on.
- There are 2 codes that are listen on the scan I posted on the other thread. (B1S1 o2 and MAF codes.)
- While running the car smokes out of the exhaust and smoke puffs out of the air cleaner when it shuts off.
- The common hardness chafe areas don't show any harness damage.
