vogelspinnen
Hi guys,
My mechanic recently rebuilt an ALH, but the engine wouldn't start. It cranks, but there is no firing whatsoever, no stumbling, no rough idle, nothing. Not even a pop. Compression is fine, everything before the ASV is disconnected so its not a choked intake. There is suction at the ASV as we crank, so air is definitely going in. ASV remains open throughout. Fuel-wise we have changed 3 known working pumps and 2 known working sets of injectors, no joy. Fuel does squirt out when we loosen the injector heads to bleed the fuel, albeit with less pressure than I remember mine having. Or maybe it's just me. Relay 109 changed as well, glow plug light comes on for a brief moment when we turn the key. We even tried a direct fuel line from the pump to a container of diesel. Vagcom doesn't give any codes, nothing looks abnormal. The only thing strnge is that vagcom does not give me a fault code when I unplug the maf.
Any ideas anyone?
Any ideas anyone?
