yotawagen
Hello everyone. I have been following tdi club for awhile now and I need some help please. I found an ahu engine and swapped it in to replace my thirsty V6. the engine is in place and the wiring is done. I can read the ecu using vcds and I don't have any codes. The problem is the i can't get to start.
I have the ecu tapped in with the efi relay and kept the intank pump hooked. The cel and glow plug lights are hooked up. The injection pump doesn't seem to work though. i cracked open all the injectors and no diesel is coming out.
The sweeper arm inside the injection pump doesn't much. I opened the injection pump and disconnected the fuel before i started turning it over and the sweeper arm in the pump makes a single movement. that's it. just wondering if there's something i can do to fix it. Any help would be really appreciated.
