Here is an interactive link to a TDI conversion shopping list. Please feel free to add or correct.
TDI Conversion List
RJ
Great !!!!!
the flywhhel is from the AHU engine ......turbos is as you prefer ,
I have a K24 , some friends have K14 , some VNT`s ...
but you have to get the apropriate manifold & intakes from older versions, ...if you keep the K03 the original manifold & intake will fit .
I went .216 injectors + K24 turbo and a chipped ECU .......
what a power improvement !!!! still very good on fuel consumption too !
the engine bolts right on the bellhosing without any mods ( both bolt patterns already )
presently I run a .756 5th gear from a CTN gearbox .....quite stisfied,,,,,
2900 rpm @ 60mph
a friend tried a .658 ,,,,,,,,,,, engine logged coulndt take the 2200 rpm ...those trucks are heavy for a 1.9L ..........
you have to keep the donor ( AHU) wiring harness ......the TDI passat cluster is identical to the eurovan ....
if eurovan is from 92-95 the right motor mount is the same
if a 96- version the V6 motor mount ( or maybe ABL too ) has to be use.....
