markward
If you want to get started in rally in the US, you might want to start looking here. http://www.scca.org/hub.aspx?hub=2 The SCCA is a good place to start.
For Rally,in the US, start with the following:If you want to get started in rally in the US, you might want to start looking here. http://www.scca.org/hub.aspx?hub=2 The SCCA is a good place to start.
What clutch is that? I see its spec but what 'stage'?
Call NGP racing and talk to Arno, they have what you need....Can you post a link to that steel oil pan that fits an ALH?
Yup, just cal your local Spec distributor and ask for what we got...so you just called and asked for that. good deal. How much was the disc and pp?
after tubular sub frame why not tubular control arms? Really great build by the way.
b3 correct? I'm planning on useing them in my project.On the list of things to do... For now though the Passat arms are super cheap and adequate.
wouldnt you want to have a readily replaceable item like a control arm be the weak link so it doesnt take out something more expensive and difficult to replace? seems like if you went to some burly tubular control arms it could even mess up the shell let alone that beautiful crossmember with the right hit. ie in the ditch on the gas then all of a sudden theres a big rock or tree trunk there. not to mention having cheap spares.On the list of things to do... For now though the Passat arms are super cheap and adequate.
I second that..one of my friends asked why I didn't use the stiffer B4 Passat control arms instead of A3 arms on my A2 build, and that was my reasoning exactly..although I am only building a street carwouldnt you want to have a readily replaceable item like a control arm be the weak link so it doesnt take out something more expensive and difficult to replace? seems like if you went to some burly tubular control arms it could even mess up the shell let alone that beautiful crossmember with the right hit. ie in the ditch on the gas then all of a sudden theres a big rock or tree trunk there. not to mention having cheap spares.
Not yet. Got a few more small subsystems ready on satuday... Fan shroud, rear shocks, Fuel tank skid plate, some wiring, some dash stuff, accelerator pedal...Looking Great! Is it running yet?
Now the pictures I saw on FB make sense, I was wondering why you guys had cut a fuel tank in half..great idea! Also liking the long travel suspension you guys are using..is this GTI going to sit any higher than your current rig or does this just result in longer droop?Not yet. Got a few more small subsystems ready on satuday... Fan shroud, rear shocks, Fuel tank skid plate, some wiring, some dash stuff, accelerator pedal...
