xyfzrider7x
I'm trying to remove my injectors to put nozzles and having a pain
Absolutely!!It's strongly recommended you break for the slide hammer. I had all my injectors out in under a minute... Best $40 I've spent. ......
Not really.. Although it's the preferred way to do this.You need a slide hammer.
It depends how long they have been in there. There is so little space to get a wrench on there properly and use some force that if they are stuck a slide hammer is nigh well the only way to go (and the least likely to cause collateral damage and/or personal injury ).Not really.. Although it's the preferred way to do this.
If you can get a wrench on the injector and twist it back and forth (Once it's unhooked from the fuel lines) they'll usually pop out without too many problem.
I edited my post to appease.Not really.. Although it's the preferred way to do this.
I've done lots and lots of nozzle upgrades. Some come out and you're thinking 'Wow, that was easy' Others make you curse...ALOT! LOL!Quote:
