The flange of the MAF subassembly (the electronics part).... elongate the holes so the MAF sub can be rotated 4-5° CCW.
See what happens.
Might have to block the exhaust of the S-duct a bit if the MAF actual is too high.
This is a sub-project that was to begin soon as part of this overall MAF work. We've, jmur & I, have had these plans for weeks.
The angle will prolly skew the indicated MAF reading way high. That's the reason behind the testing to find out how much we will need to block the S-duct exhaust for a given twist angle. The angle of attack should help these MAFs live much longer if the apparent failure mode is what it appears to be: overheating. This angle of attack will get the incident air on the MAF die where it needs to be.
The MAF specialists have not had a chance to do the testing yet, so if you do this, you are on your own.
See what happens.
