RedDragon
So my auto trans life is coming to an end finally. Can i get some Pros and Cons to doing this swap? Please help!!! I need direct Pros and Cons. Thanks!!!
Couple thousand you mean?Get a 6 speed kit from ryanp on here. A couple hundred more than a 5 speed but now that i have one id never go back. And od go with a south bend clutch.
Then you got lucky. Very rarely do I see a 5 spd swap kit go for for less than $1200 plus a clutch.I paid about $850 for the 5spd swap I did.
I just looked in his thread and it's 1250 pounds, not 1575. It used to be 1100 pounds and that's what i quoted which worked out to $1750 USD; 1250 GBP is an even $2K USD right now. That's a negligible cost difference in a project this size.ryan p charges 1575 pounds for his 6 speeds swap not dollars, that alone is $2500. It is not a $1750 starting price.
Last I heard they were a little over $4k from VW.All this info rocks!!!! So what is the price of a new auto trans for a ALH?
The only parts you need that aren't in Ryan's kit are a clutch pedal, line, and bleeder fitting (if Ryan didn't leave it on the trans, he usually does). The slave cylinder will come with your clutch kit.Not if you need the auto to manual parts like the OP does. That price is 1575 pounds.
wowsers!!!last i heard they were a little over $4k from vw.
No i wasnt going to add anything till the auto was dead. So basically do a tune up on it? Check hoses belts ect... ve heard the term Stage 0 used before would that be correct to use?I think your dying trans will last 15 minutes if you were thinking about installing the performance package before doing the 5-speed swap. Do the manual trans swap and get everything else on the car into tip-top shape before you start up-ing the power.
When you do the trans swap, put in a beefy clutch as many others have suggested. That is the only thing in the kit that would have any relation to the trans swap. The turbo and nozzles can be done easily afterwards.
My $0.02.
I did this to my 2003. My transmission was from my wrecked 1998 with 278 (I say 280)k miles on it. I have over 10k miles on the swap to date.
I bought this car and did all the suggested upkeep to the auto and drove from NC to New Mexico for the New Beetle GTG and averaged a pitiful 38mpg for the trip. Looking at logs the best highway tank was just shy of 46mpg, the 98 I was replacing tgot 42-43 in the city and 48-55 on the highway -- the last 6 highway trips had all been 52 or better MPG before the wreck.
This was not acceptable. I averaged about 34 in town.
After the swap you can check my fuelly... 42 is the average. I dropped to 38 at the end of the winter, needing a fuel filter change (this was made more evident after I flashed the car with performance software). I drove with all the windows down at 65 to/from Greensboro and got 48.6 (49.1 if I didn't "top up" with the extra .10 gallon)... with the sunroof shut (my 98 didn't have a sunroof) I bet I could have bested 50mpg on that trip.
I'm hoping to go to Mississippi this May and have a goal of avg speed 61mph and avg mpg of 54mpg (758 miles one-way).
So, based on this alone, if you clock decent mileage you will recoup the swap costs in about 2-3 years time. Less if you do a lot of highway traveling.
Plus a manual TDI will always carry a better resell value, because the autos will get scrapped and these will still be around.
Next upgrade is a taller 5th gear.
Only if you want to spin 3500 rpms down the highway in 5th...I have a friend that is selling a trans from a gasser with code 02J 300 044 F. Will that work?
It'll bolt up but the gearing is wrong. You could get a taller 5th gear to install in that gas trans to get the hwy fuel economy... but... I'd try and find a diesel transmission.Only if you want to spin 3500 rpms down the highway in 5th...
