Go Back   TDIClub Forums > VW TDI Discussion Areas > OBD Scanners
OBD Scanners Discussions on using On Board Diagnostic (OBD) scanners/ Diagnostic Equipment related to TDIs
Old February 26th, 2020, 15:07   #1
gbrandt
gbrandt's Avatar
Fuel Economy: 64/50/37
Default VCDS Works but ScanGauge does not
Hi,
I have an ASV 1.9 TDI installed in my Vanagon (T3). I have a scangauge that simply will not connect to the ECU. Actually I have two, one much newer than the other and they both do not connect.
I have a VCDS (Vag-com) that connects perfectly well.
My used pins on the OBDII connector are 4, 7, 15 and 16
I have tried forcing KWP protocols with no success. Any idea on what may be going on?
Thanks,
Gregor
gbrandt is offline   Reply With Quote
Old February 27th, 2020, 02:41   #2
Rxfire
Rxfire's Avatar
Fuel Economy: 41-44 at 75 mph w/ no a/c
I fried a ScanGuage hooking up to a TDI with an aftermarket radio in it. Do your ScanGuages work on other cars? Mine would not work at all after that incident.
2 each 2003 GLS Jetta Wagons (White/tan leather and White/black leather), 5 speeds, Panzer plates, roof rack cross bars (hers), homelinks, 520 nozzles, ventectomies, trailer hitch (mine), VR6 front springs (hers); 1 inch lift kit w/ESP (mine) 1985 Isuzu P'up NA Diesel
Rxfire is offline   Reply With Quote
Old February 27th, 2020, 10:53   #3
gbrandt
gbrandt's Avatar
The scangauges do work on other vehicles.
I am now thinking that it's the missing ground on pin 5.
Someone has also told me that switched power to pin 1 is also required but I see no evidence for this elsewhere.
Old February 27th, 2020, 12:30   #4
oilhammer's Avatar
Fuel Economy: fantastic
I do not have any help for you other than to say (and you probably already knew this) that VCDS uses the native VAG protocols and connections at the DLC. A Scangauge (or any other generic OBD2 device) will only use the generic part of the DLC.
This may help you decipher what you need and what is missing:
https://en.wikipedia.org/wiki/On-boa...stic_connector
www.cardocautomotive.com
Old February 27th, 2020, 13:20   #5
gbrandt
gbrandt's Avatar
Ok, I can see the VW used pin 1 for switched power, but odds are very good the ScanGauge would not use that since the ScanGauge is a universal product. I'm putting my money on grounding pin 5. Will update after I've done that.
Gregor
[VCDS] N/A displayed in mesure block (and so on TDI grap) but advanced mesure works ! bigboss59400 OBD Scanners 3 November 28th, 2015 14:25
WTB: VCDS and FS: Scangauge II Slowrvr Ontario 11 August 1st, 2013 08:46
VCDS No response from Contoller, but SnapOn code reader works AARodriguez Corp. OBD Scanners 13 December 15th, 2012 18:20
HELP: New Macbook Pro 2012 (USB 3.0) + VCDS + Fusion no longer works SFHGolfTDI OBD Scanners 22 November 11th, 2012 14:57
ScanGauge and VCDS question AndyBees OBD Scanners 0 September 21st, 2011 08:05
Page generated in 0.14712 seconds with 13 queries
[Output: 70.89 Kb. compressed to 62.82 Kb. by saving 8.07 Kb. (11.39%)]
