Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old February 15th, 2020, 17:19   #1
tomo366
TDI Lifer, Member #131
tomo366's Avatar
Default DEF Leak....
I have owned our 2015 Jetta SEL TDI since New it is 5 years old this week was Phase 2 Fixed a year and a half ago.....Wife drives it now so I do not get to drive it much....Any way open the Hood last week to change the fuel filter and Air Filter and found the DEF Fluid Leak around the injector..... caked up good....I took it to VW they had the car 3 Days.....seems they have to involve VW on any Emissions related warranty repair got it back yesterday said it was a hose not the sensor....will keep a close eye on it
My page is Dedicated to the Memory of
Christopher Farnham RIP my friend!
Great friend and supporter of TDICLUB
2015 Jetta TDI SEL Tornado red
2014 BMW 328D XDrive Glacier Silver
2015 Jeep Grand Cherokee Overland EcoDiesel
2004 Jeep Grand Cherokee Black!
tomo366 is offline   Reply With Quote
Old February 16th, 2020, 11:09   #2
akjdouglass
akjdouglass's Avatar
Our 2015 Jetta SEL TDI is at a dealership 128 miles from home for the exact same thing. CEL and DEF light came on as she was driving. Knowing that DEF will freeze, I'm assuming the recent cold weather has something to do with this (6 deg. F for a couple nights). The crystallization is obvious without even removing the engine cover.
She dropped the car off at the nearest dealership after hours and I drove there to pick her up. If the repairs are made within 1 week it won't be worth the hassle of getting a loaner from the dealer.
The 2015 had been trouble-free up to this point, especially compared to the hydro-locking issues I've had with my 2014 TDI each winter. Howerver, I've gotten pretty good at pulling glow plugs, disconnecting fuel pump wires and cranking the engine a few times to blow the water out of the cylinders. It may be a PITA but at least I'm back on the road in 30 minutes.
Hopefully, the DEF issues don't become recurrent, nagging occurrences.
akjdouglass is offline   Reply With Quote
Old February 19th, 2020, 17:45   #3
hikertdi
This is a fairly common issue, I had it on one of my two 2015's also last July @ 57K which I saw when doing an oil change. It wasn't bad enough to throw a code at that point. Here's the service bulletin I found on the subject.
https://static.nhtsa.gov/odi/tsbs/20...55774-9999.pdf
From what I found out last summer, the normal process is to just replace the DEF supply line, clean up the crystals an generally leave the actual DEF injector unchanged as the bulletin states. I had no issue having it done under warranty, but it took a few days to get the DEF line.
The bulletin shows the possible VINs impacted and models. It states it was a weld process problem and new parts correct the issue. My newer 2015 (leftover I bought in April 2017) is not in the VIN range, only my 6-MT which I purchased as a buy-back was in the range.
I have yet to do phase 2 on either car. Aside from this DEF supply line, I have not experienced any other repairs on either car.
15 Jetta SE 6-MT
15 Jetta SE DSG
09 Jetta DSG (Buyback)
00 Jetta 5-Sp Manual (Sold)
hikertdi is offline   Reply With Quote
Old February 19th, 2020, 18:38   #4
akjdouglass
Worth mentioning that code P20E8 was my first symptom. I had serviced the car less than 3000 miles before and there was zero crystallization at that time.
I reluctantly decided to let them do phase 2 while the car is there. Since my mileage is under 40,000, the dpf is supposed to be replaced again at some point before reaching 150,000 miles.
Old February 19th, 2020, 18:40   #5
tomo366
tomo366's Avatar
Mine didnít throw a code
Old February 21st, 2020, 18:20   #6
bglf83
TDI(s): Jetta
Mine did not throw a code either. They replaced the injector.
bglf83 is offline   Reply With Quote
Old February 23rd, 2020, 06:40   #7
timfarn
If the injector looks like a snowball, you will return to replace the adblue injector. 90 miles to nearest dealer, we agreed to replace injector, they replaced only the supply. Two weeks later, it looked the same. I was not happy about the return trip killing a day.
Sent from my iPad using Tapatalk
timfarn is offline   Reply With Quote
Old February 24th, 2020, 14:25   #8
tomo366
tomo366's Avatar
Mine is leaking again less than 2 weeks after the repair.....
Old February 25th, 2020, 10:03   #9
oilhammer's Avatar
Fuel Economy: fantastic
Common. TSB about it. Improved reductant supply line. Although if it is not installed exactly right, it can leak again. Area has to be squeaky clean when it snaps on.
TSB 26-19-01 2039436 (this is the SECOND TSB on this issue, btw).
www.cardocautomotive.com
Old February 26th, 2020, 06:50   #10
tomo366
tomo366's Avatar
Had this car for 5 years (a record for me) and never have had a problem until now about a year and half after the Phase 2 Fix
Old February 26th, 2020, 10:06   #11
oilhammer's Avatar
Yeah, plenty had the issue when they were 6 months out of the factory, too. Hence the multiple TSBs, the first one was dated some time in 2016.
Old February 26th, 2020, 22:27   #12
akjdouglass
Ours got Phase 2 while it was in for the broken tube. Wife's been driving the car for 4 days since we picked it up.
Hopefully I won't wear out the hood hinges looking for the def leak to return. Don't want to make frequent visits to the dealer even though warranty covers it all.
Old March 5th, 2020, 14:17   #13
tomo366
tomo366's Avatar
Took mine back on Monday.....they replaced the valve this time....Service said 7 of 10 come Back after they replace the Hose they then replace the Valve.....This is typical VW
What is this? DEF Fluid Leak? DieselDiesel VW Passat Family (NMS and B7) TDIs (2012+) 28 January 11th, 2020 11:50
2013 Def leak BrentTheBoat VW Passat Family (NMS and B7) TDIs (2012+) 1 October 21st, 2019 13:20
DEF leak @ injector under hood, NO START -2015 Jetta dx1001 TDI 101 8 April 25th, 2019 07:59
DEF Leak ddorrer Dieselgate - VW Group Emission Scandal 1 April 27th, 2018 17:38
Oil leak. Coolant leak. Injection pump leak. Chris_TDI_98 VW MKIII-A3/B4 TDIs 3 April 23rd, 2016 11:00
Page generated in 0.14948 seconds with 13 queries
[Output: 118.90 Kb. compressed to 99.89 Kb. by saving 19.01 Kb. (15.99%)]
