My 2005 Jetta TDI did NOT pass the Arizona emission test yesterday on the first attempt (was first time required). A pollutant rating (called a OPACITY), looking for a base number of 20, measured something like 27 or 47, I really forget which. IT FAILED.
Derek Scott of Exklusive (www.[B]exklusiv[/B]motorsports.com), my guru in Phoenix, recommended 1) I use the manual position of my auto/shift tranny and drive back across the city some 15 miles to the DOT testing location, and 2) DO NOT turn the car off while waiting to get into the testing stall. Derek explained the catalytic converter must be a full operating temperature when the emission test is done.
RESULTS: The drive back resulted in the RPM's in a range between 3,000 and 4,500 RPM, much higher RPM's than my normal type driving in the automatic mode. My wait for testing was just 12 minutes and I did NOT turn the engine off (first test wait was 30 to 45 minutes and had shut car off much of the time). OPACITY rating on new test = 3.9 ! .... PASSED.
