AmIdYfReAk
Hello all,
This may be a little of a long read, but here goes...
As the weather here in southern ontario gets colder and colder, there is a more and more apparent cold starting issue with my ALH.
The easiest way to describe it, it sounds like a lumpy cam'd motor and shoots smoke out the back for a few revs then everything is normal till it sits for 8+ hours.
So the car in question:
2003 jetta w/ALH
DLC1019's mounted and balanced by DBW on stage 5 pop pressures
11mm pump w/ lift pump
ARP head studs
17/22 turbo
FMIC w/3bar map
2.5" straight pipe exhaust
mafless tune
Now what i've done:
Compression check, 400 across the board
Moved the pump timing back and forth across the timing range.
Replaced the starter ( old one was lazy ) , glow plus, maxxed out the glow plug adjustment via vag-com. Played around with SOI in the tune, as well as raising minimum fuel RPM from the pump voltage, all no change.
So should i be looking at the pump as the issue? Software? IQ?
Also, whats the "normal" fuel temps for an 11mm pump? I'm seeing 110+ while out driving around... Eesh...
Here is a good youtube video showing it its worst its been... ( enjoy the "really canadian eh? Accent... Ha! )
http://www.youtube.com/watch?v=TwkdUmCN_xU
Thanks!
2003 jetta w/ALH
ARP head studs
17/22 turbo
FMIC w/3bar map
mafless tune
Now what i've done:
Thanks!
