Old September 7th, 2009, 12:35   #1
crazycode
Fuel Economy: 42mpg
Default i think i messed up. help!
i just put my turbo back on my 210,xxx mile jetta. i had it off due to sticky vnt mechanism. i replaced the oil feed and drain lines while i was in there. i was reassembling the turbo and checked the vnt to make sure it was moving freely (which it was) but it would not move back far enough to touch the adjustable stop. there was a good 1/4 inch gap between the adjustable stop and the vnt mechanism. i quit for the night and forgot about it and put the turbo back on the car the next day. now im over boosting (35psi stock vnt15) and going into limp mode and its really sluggish. any ideas???
thanks!
crazycode is offline   Reply With Quote
Old September 8th, 2009, 07:54   #2
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
The actuator is probably your issue. Was there ANY binding on the arm on the turbo though?
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Old September 11th, 2009, 16:19   #3
crazycode
Fuel Economy: 42mpg
well i took the turbo off for the second time now. thanks jasonTDI but the problem was with the ring that moves all the veins. i had it aligned correctly but it was upside down. lol. flipped it back and put it back together and now it runs like a champ!!!
Page generated in 0.11294 seconds with 10 queries
[Output: 53.26 Kb. compressed to 48.07 Kb. by saving 5.19 Kb. (9.75%)]
