Searcher2
About a year ago had to replace the window regulator cable. I elected to change the entire plate with cables and guides already in place. Six months there abouts I had to change it again with one from the U-pull-It. A couple months later I replaced the cable, and now it's broke again. I checked the window for binding up and down and the only thing I found was a slight drag when the window was about an inch from the top (it didn't appear to be serious). Yesterday I heard a slight pop when the window reached the top,and I lowered it a little and raised it back up. That's when I heard the cable separate. What is the likely culprit here? I would rather repair it than get a door from a salvage vehicle that could have the same problem Unless I happen to find one that has a door card that isn't as destroyed as mine. Thanks for any ideas.
