samsonight
Howdy ya'll,
So about a week ago my 2001 Jetta TDI 5 speed started having difficulty shifting.
There is no grinding unless going into reverse. when the car is shut off I can select any gear just fine. As I go up in gears it becomes easier to shift.
This has happened in the past, but I would just pull over and pump the clutch/turn the car on and off/shift through gears and the problem would go away.
I just replaced the slave cylinder and bled it and the problem still persists.
The clutch pedal works fine, engages 3/4 of the way down to the floor.
How screwed am I?
How screwed am I?
