Bierrie
Hi everyone
Over the years I've learned so much from this forum, that a big THANK YOU would be in order!
Recently a problem has developed which I haven't been able to diagnose 100% accurately. Perhaps our old faithful is starting to show her age? This 2005 VW Golf 5 BKD 2.0 TDi 6 speed MT now has 240K kms on the clock. As a side note, I replaced the transmission oil recently with Castrol BOT 402.
Most mornings when I start the car, there is this grinding noise – similar to the sound of a worn timing chain tensioner of yore. This is only audible on cold start, car stationary, with the transmission in neutral and with the clutch pedal out. The moment I press the clutch pedal in, the sounds goes away. If I let the engine idle for a few minutes, this noise also disappears. I have not noticed this noise while driving (but that might be due to other noises).
The second problem is even more sporadic. Perhaps unrelated? And it only happens when the car is at operating temperature. When I shift gears, the clutch pedal would not come out completely. It is kind of sticky ... if I can explain it that way. The pedal would travel smoothly in but not return to its rest position in one movement. It would come out 70% and then pause before popping completely out.
Oh, and a final remark, 1st gear seem difficult to engage when you stop, press clutch pedal in, car stationary, engine running. To overcome it I first put it in 2nd and then 1st. I'd hate to start changing parts on suspicion, so please advise how I should test to improve my diagnosis.
