v8 coupe
Can this be done? I've seen some discussion of it, but no yes or no if it's possible. Looking at different options. looking at 12v VE nozzles
It's not 'bolt on'. The needle end is different, and spray angle is also tighter that our 150*.Can this be done? I've seen some discussion of it, but no yes or no if it's possible. Looking at different options. looking at 12v VE nozzles
That is not true. If the holes are in correct angle there are no problems. I'm running 8-hole cummins nozzles on my tdi like 3 years soon ... thats about 90000km now.If you have too many holes, jet-to-jet interaction will result in lots of smoke and HC and probably burned pistons too. There is an optimal number based on bowl and spray geometries, as well as degree of swirl.
+1re-engineering the wheel again ? There are a tdi specific nozzles out there that can flow enough fuel for over 350hp.
Are there? Haven't seen any.Re-engineering the wheel again ? There are a tdi specific nozzles out there that can flow enough fuel for over 350hp.
Show me the people who need more fuel than is available from current offerings?350 is good and all...but what is stopping us from going for more?
that is the question that has plagued me for a while.
Yup.Re-engineering the wheel again ?
I offered and no one really seemed interested. I can have high quality nozzles made in any size wanted all the way up to (and probably over) .025" holes. The company making them laughs that the biggest I've ordered form them is the .013", they're used to making .020+" sets for drag/sled guys.350 is good and all...but what is stopping us from going for more?
I don't think that the 7 holes CR Cummins will work in our TDI, yes, the nozzle looks the same ( I have a set here ), but because the injector of the CR is just above the piston bowl and the TDI injector is angled, the entire spray of the CR nozzle won't reach the bowl.Well in some cases cummins nozzles are only way to go when upgrading tdi for more power. There are no nozzles available for my tdi. 8-hole nozzles out from 03-04 cr isbe is way to go 280+hp. Spray angle is close enough compared to stock 142 vs. 143.
Well the I don't know about 7-hole nozzles. My TDI injector is center of the piston and the bowl so only thing that I'm worried is spray angle is one degree wider than in stock nozzle. It should be less than 142 degrees. Narrow angle allows more advance. Only upgrade nozzle that is available that I know.I don't think that the 7 holes CR Cummins will work in our TDI, yes, the nozzle looks the same ( I have a set here ), but because the injector of the CR is just above the piston bowl and the TDI injector is angled, the entire spray of the CR nozzle won't reach the bowl.
could I use all Nozzles for the v6 tdi from 03-04 Cummins 24v?Well in some cases cummins nozzles are only way to go when upgrading tdi for more power. There are no nozzles available for my tdi. 8-hole nozzles out from 03-04 cr isbe is way to go 280+hp. Spray angle is close enough compared to stock 142 vs. 143.
