Golf died on the road....
...and this thread helped me solve the problem. The car is a 99.5 Golf TDI automatic, and the short list of codes that it threw began with the "Fuel Cutoff Solenoid Open or Shorted...", "Fuel Temp Sensor Ckt Fault", and the ever popular "Glow Plug Ckt Fault".
The fuel system was checked from tank to IP, and the MyTVac pulled fuel clear through the IP and out. Fuel filter was fresh, and the ASV was also checked and found to be open.
10-pin connector on the IP was clean, as was the connection on the Fuel Cutoff Solenoid. Solenoid was removed, checked, reinstalled, and tested - OK.
I am now dreading that the ECU has gone south, and I am not looking forward to trying to mess with it. I then decided to pull the battery & the tray to have a look at the starter motor and the battery cables, and everywhere I go I am 'HOPING' to find a corroded connection.
All the while, I am shuffling back & forth from the garage to the computer, reading and rereading this and about a half dozen other threads on this subject.
As almost a last resort on my way to ECU hell, I trace the wire harness from the 10-pin IP connector back along the front of the engine, over the starter - and through the plastic protective sleeve above the starter solenoid. I removed the well wrapped wire bundle from the sleeve and examine it - and promptly find a spot on the bottom where the wrap, insulation, and at least 6 wires have worn through - one of them completely severed (Fuel Cutoff Solenoid- Black/white tracer). YEAH!
Needless to say, after splicing new wire into the burned & shorted spots (and sealing them with heat shrink tubing), the Golf magically came back to life, and the VagCom showed no more faults.
I must also say that without the excellent pictures on this thread and the site in general, I would still be out in the driveway right now testing components. This one really had me scratching my head.
Thanks so much!!!
George
