Ironman11142
when getting on highway, is slow or quick acceleration to highway speed better in your opinion?
looking forward to responses...
Yup. Get up to the speed of traffic or a bit faster, find the hole, and merge.Quick acceleration.
Have you ever been stuck behind an idiot who doesn't know how to merge? They putter along in the merge lane going half the speed of traffic, and then they run out of room and stop, potentially causing a massive pile-up and multiple deaths.
So I would say get up to highway speed quickly, and merge. You only have so much room to do it, and that basically dictates how fast you have to accelerate. Generally, the sooner you're up to highway speed, the more options you have in case something goes wrong. You can still slow down again to merge behind someone, which might be easier than speeding up even more if you had to do that.
It's ok not to agree.Jettawreck, I don't agree. If it only takes 4-5L/100km to stay at speed, accelerating to that speed quickly (assuming no traffic lights, jams, etc. ahead) so I can cruise sooner nets a better average overall. Accelerating, even slowly, is usually 12-20 instant L/100km, so the momentary time spent at very high consumption is more than offset by reducing to steady cruise consumption sooner. As an added benefit, you prevent traffic buildup behind you by not impeding traffic that's already up to speed. It seems nobody around town knows what the tall skinny pedal is for anymore...
heard various theories about slow and fast acceleration vs. fuel economy
just wanted to hear some real world opinions....
personally, I like to get up tp highway speed ASAP so that engine can get to fuel sipping range quicker
Floor it. It's the time to clean the plumbing... a good 3rd gear pull... check your mirrors, pick a spot, and merge in at a proper hwy speed. Then hit cruise.
That's probably the best advice, if you spend most of your time at speed. Get going and settle in.Fuel mileage. ..whatever. efficiency..WHATEVER. engine load blah blah blah. Studies. ..tests...schmests.
You're merging on a hwy!
Get up to speed. BLEND in...then pick your/a cruising speed.
I thought the trick (pulse and glide) was to coast down in gear. As long as the rpm is above idle it will use no fuel. If in neutral some fuel is used to maintain idle rpm. I am just breaking myself of the habit of putting it in neutral when coasting down to a stop.T...... You can recover some of the spent energy in acceleration if you look ahead to slow down by putting it in neutral and coasting down to a lower speed. The more you use your brakes the more energy (originally from the fuel) is wasted and the lower your mpg.
It sort of depends on what you are trying to do. Slow down instead of using brakes or (coast in gear) or maximize the coasting distance (neutral).I thought the trick (pulse and glide) was to coast down in gear. As long as the rpm is above idle it will use no fuel. If in neutral some fuel is used to maintain idle rpm. I am just breaking myself of the habit of putting it in neutral when coasting down to a stop.
It's a little more Physics than just crunching numbers with mathematics."I thought the trick (pulse and glide) was to coast down in gear."
I'm not sure I understand why this is always brought up. Yes, if you coast in nuetral the engine will idle and use a LITTLE fuel. If you coast in gear the engine will use NO fuel until around the thousand rpm mark depending on the car. So, most people compare LITTLE to NO and make the leap that you''ll save fuel by using NO fuel coasting in gear. EXCEPT, coasting in gear means you can't go nearly as far which means you'd have to use the throttle to make up the difference or start coasting later. It's math, there's no way around it.
