TDI-T
My number 1 bearing cap is further in than the bearing on the block. I've never seen this on another engine. Can anyone confirm if this is normal? Not sure how it could be wrong, but I didn't take a look before i pulled the other crank. Hopefully the pics explain a bit better.
https://imgur.com/gallery/Zyadp
Yes, I did double check and the cap is on the right direction Crank seems to rotate fine, too.
