Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old February 16th, 2017, 21:30   #1
dosel
Default 19 Wheels want to lower
I have a 2012 Jetta TDI with 19's. The tires do stick out a little bit from the fender and I want to lower about an inch or so and make 2 inches in the back to make it sit level.
What can I install to do this?
dosel is offline   Reply With Quote
Old February 17th, 2017, 20:33   #2
chaoscreature
chaoscreature's Avatar
Fuel Economy: Good Enough
If you want to lower the rear more than the front by an inch, you might need something with an adjustable spring perch for either the front or the rear. Basically this will be a coilover type of kit, even though the name is a bit of a misnomer.
Since you have no camber adjustment and your tires already sit proud of the fenders you might have some rubbing issues... just a thought.
I am running H&R Sports and the car sits pretty level.
"If everything is under control, you are going too slow." - Mario Andretti
2006 Jetta TDI Special Edition
2012 Jetta TDI 6Spd Premium
chaoscreature is offline   Reply With Quote
Old February 17th, 2017, 21:14   #3
dosel
Is it possible to just drop the back an inch or so and keep the front stock? Without cutting of course
Old February 20th, 2017, 16:31   #4
travis45
travis45's Avatar
How do you like the H&R sports? What shocks do you have paired with them? I have a set for my JSW. Still trying to decide what are the right shocks. Was thinking Bilstein Sports or HD's.
14 Sportwagen TDI CR170 Turbo, Rawtek turbo back exhaust, Malone Stage 3, CP3 Fuel Pump, Malone DSG Tune, Panzer, 19" Konig Oversteer Wheels, Fluidamper Crank Pulley, H&R 22mm rear sway bar, PolarFIS. Soon to install Darkside intercooler and piping, Wavetrac LSD.
travis45 is online now   Reply With Quote
Old February 21st, 2017, 21:31   #5
chaoscreature
I am running Koni Sport shocks with the H&R. I ran the OEM shocks for almost 40k miles with no issues, I just wanted something firmer. The Bilstein's are of course also very good shocks.
19 inch wheels VMR? chgofirefighter VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 65 June 13th, 2013 08:26
19" wheels fflis VW MKIV-A4 TDIs (VE and PD) 3 July 13th, 2010 08:50
19" wheels jrad12381 VW B5 Passat TDIs 5 November 22nd, 2009 16:30
19" wheels and 225/35 19 v70rsik TDI Fuel Economy 31 April 15th, 2007 15:06
19 inch wheels shortly to come Youry Upgrades (non TDI Engine related) 21 July 15th, 2000 10:54
Page generated in 0.13289 seconds with 13 queries
[Output: 68.99 Kb. compressed to 60.97 Kb. by saving 8.02 Kb. (11.63%)]
