Veloseller1
COLORADO PD140 BKD TDI 2.0 16VVNT 17 Turbo Vanagon swap w 2 ECU&Custom wiring harness
[/IMG]FOR SALED140 BKD GERMAN MARKET 2005 GTDI 2.0 16V Thttp://https://www.dropbox.com/s/qbby8xz39f8neny/20lstand.jpg[/IM
VW TDI PD140 BKD 2.0 Liter 16V DOHC TDI
PD 140, eng, code BKD. came from germany, has low miles, came from 2005 MK V, VW golf, GDTI. Has 140 HP and 268 ftlb of torque. Comes with whole wiring harness from instrument cluster to motor, eng computer (ECU), Also comes with a second harness, ECU, original (VNT) turbo, brand new (MAF), Instrument cluster, pneumatic emissions control box, key with lock cylinder, various other extra parts and pieces (brackets, water pump, power steering pump, comes with flywheel and dual mass clutch assy. bolted on, the eng is in one piece Also comes with custom couplers so you can run aftermarket intercooler.
***[COLOR="Red"]I bought this BKD SWAP from rotopimp & Sent the complete wiring loom &two ecus's to Dave Marshal ofHasenwerk in Canada and had a custom wiring harness made for Vanagon use. Dave is an expert on Vanagon TDI wiring harnesses. This alone was around $1400If I remember correctly?
[/COLOR]
BKD PD140 2.0 16v MOTOR WITH CUSTOM VANAGON PLUG AND PLAY WIRING HARNESS INCLUDED IN THE SWAP
ASking $5000 or best offer. Thats roughly $3500 forvery rare in Usa?PD140 motor & $1500 for the customVanagon Harness,2 ECU's & ECU work., ALL someone would need to install this is the Eurospec sport BEW TDI advanced install kit & an exhaust!
Or maybe a Kenedy adapter plate and some custom fabrication
This will be really amazing in a vanagon syncro!
The Motor is located in Colorado. I can do photos of the custom wiring harness with the motor if someone is interested?
I also have a 1987 Mercedes 300TDt wagon for sale if anyone is interested?
[IMG]http://imageshack.us/a/img829/8986/20lstandg.jpg
970-988-9046 Motor located in Colorado!
jmvbike@gmail.com
[/COLOR]
jmvbike@gmail.com
