tleader
I've looked around a bit and could not find any info on the Black Forest Industries motor mounts. I believe it is time to change out the mounts on my 98 A3 Jetta, but would like a slight upgrade form stock. My car is pretty much a daily driver and I make quite a few long trips thoughout the month.
I looked up the mounts on BFI, but it does not show an application specifically for a TDI. I've written them and I am waiting for a reply. Would there be any reason not to upgrade the mounts to a slighly stiffer/better composition other than the OEM rubber mounts? The BFI are cheaper and would seem to outlast the OEM, from the description and physical make-up. Do the TDIs require specific mounts compared to the gassers, due to weight or engine vibration?
Has anyone had any experience with BFI mounts and if so, what was your impression? Any help or advice on motor mounts would be appreciated.
