Car has 363K miles stock internals and trans (THIS IS NEXT when i have money lol*)
98 TDI MK3 Jetta (I did 100% of all the fab and work on this car save for the head rebuild and glass)
Head / Intake
Fully ported and polished head
Decked and rebuilt head with ARP Studs with 15ftlb over torque
Undercut valves
Colt 2 cam and better springs
PD150 intake manifold
Custom intake adapter to 2.5”
Cam sprocket bolt at 49ftlb with blue lock tight!
Custom made coolant flange upper and lower (NO PLASTIC, ALL ALUMINUM)
CCV delete and vent to ground near exhaust
100% water injection from WW reservoir DIY
Turbo / Exhaust
GT2052
Custom intake adapter to stock swish cheese air box
2.5” FMIC *eBay
eBay cast manifold
Custom 3” exhaust strait back from turbo and coming out the driver side behind rear wheel in lower plastic 9” past
EGR delete
Fuel
Nicktane uber kit with CAT filter
Walbro pump 11 psi idle and 9.2psi WOT
PP .764 5 hole stage 3 pop tested and tuned by KERMA
12 row cooler on return
Tune
1.4 I.Q
Stage 6 custom tune from MALONE
Basically as much fuel and boost as I can get
3 BAR map chip in ECU from MALONE
Boost valve set to 29 psi
Gauges
Auber gauges
Oil psi
EGT right into the turbo about ¾” from fins
Boost PSI
Scan Gauge II
F* Coolant Temp
F* Intake Air Temp
MPG
62 mpg freeway, long distance on cruse control
39 mpg daily driving average
28 mpg driving the way I do
6 mpg (YES 6) when I go autocross or any WOT event
TIRES / Suspention
205/40ZR-17 SUMITOMO HTR Z II
17x8 Axis OG Europa SDC
Bilstein HD struts
Eibach springs with 1.75 drop front and 1.25 rear
Prothayne Poly bushings on everything
HD strut bearing cap
Braking
Hawks HPS pads
Slotted and drilled rotors
ATE Gold dot3
Interior / exterior
12” eBay steering wheel
Passat lighting and LED map lights on all bulbs
Headliner custom
Upper glove box
Remote Key fob aftermarket
Kenwood head unit
Kenwood speakers all around stock locations
250 mini amp
2400 watt amp
2x 12” sub full box in trunk
AIR ZENITH 3/4hp 80 amp air compressor
2x 3 gallon aluminum air tanks
Horn blasters quad train horns under trunk (triggered from Cig Lighter turned ground switch
Train whistle up front
3 pairs (fogs 2300K, high 6000K, low 5000K with cut offs) HID
Projector headlight dual with LEDs turn signals
3 tier grille badgeless
eBay Euro front bumper (needed the clearance for FMIC)
Fogged rear tail lights
