Hello Forrest,
Thank you for asking!
I have a couple options for you:
Right now:
CP3 pump kit. It's more than well proven to allow you to forget the HPFP concern and have the ultimate piece of mind for fuel system reliability. 100% bolt on, plug and play with no ECU modifications required. Works perfectly on a factory emissions car up to and beyond our current "stage(s)" of tune.
Many report easy installation, factory look, faster starts and a very minor increase in fuel economy. Comes with the One Micron filter head, filtering your fuel after the factory fuel filter, giving you the cleanest, best chance at water free fuel fed to your new pump and injectors.
Option #2
The original "Contain Flow" filter kit. New one piece design with no fittings to leak. Uses the CimTek 70025 one micron filter to filter the return fuel from your factory HPFP, protecting your low pressure system from pump contamination. These are available right now as well.
The Contain Flow kit above should be paired with the original Pure Flow kit that is coming back soon..... very soon.
It's also a one piece design, no fittings to leak, see pictures a few posts back.
Send me an email if you wish and I can give you pricing options.
Thank you,
Andrew
tdi2micron@yahoo.ca
