coolvdub
Hi all,
New guy here. I have had my '01 Jetta for about a month now and have been fixing all the small problems 1st while recovering from a failed tranny on the way home after purchase.
So I know I need to change the TB ASAP with a quality kit. I will be getting one of the 100k kits so I won't have to do it again for a while.
So my last tank netted 50.2 mpg and I am happy with that for now. Looking to be at 52-55 mpg when all is said and done. That being said,
I finally checked IQ and IP timing today. The IQ was at 2.0 and I bumped it to 3.0 to see how it affects mileage. Also the IP timing was in the retarded range at 35 which is costing me a few mpg. So my question is, when a TB stretches will you see retarded timing like I have now? Would it be wise to advance it via the pump to be closer to the blue line until I change the TB, or should I leave well enough alone.
Also what is the best value to shoot for in regards to IP timing advance for the best power and mpg. I read it somewhere, but can't find it now via the search, so if you can direct me to a specific post on this it would be much appreciated.
Don
Don
