DanG144
After replacing the DMF in a DSG yesterday, we had problems with the power steering not recovering properly. Can anyone think of something that we could have done during the DSG replacement that could cause this?
The battery was disconnected for 8 hours or so. No charger was put on it, no effort made to keep any keep alive power to the system.
The power steering would function for a few seconds erratically, then the malfunction indicator would come back on. After clearing the codes on the car we had the remaining issues.
The J500 Power steering Control module is obviously not communicating properly on the CAN bus.
We did unhook the battery again, and in desperation, even touched the positive and negative cables together for 30 seconds or so. Same behavior and same codes still existed.
The fuse to the J500 is good and has power on both sides.
(edit after post #4) Yes, I should have mentioned that we did drive the car, follow the procedure for resetting the steering, lock to lock for 5 seconds each, then straight, then turn off the key, then start and drive straight, repeat until sick. It did not help. The car was driven for more than 10 miles total. (end edit)
Any help in troubleshooting would be appreciated. I barely can spell CAN Bus, much less trouble shoot it. I understand the basic concept, but beyond checking voltages and continuity, I am over my head.
http://wiki.ross-tech.com/wiki/index.php/01309 gives some good starting points. I will take the actions specified in the WIKI (Thanks Ross-Tech!), is there anything else I should do after that, or would I be down to simply replacing the J500 Power Steering module?
Any thoughts are welcome.
Dan
Chassis Type: 1K0
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWST71K36M819953 Mileage: 173390km/107739miles
00-Steering Angle Sensor -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Cannot be reached 1100
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Component: ESP FRONT MK60 0102
Revision: 00H13001
Coding: 0021122
Shop #: WSC 00066 000 00000
VCID: 71E339B868B23B1
1 Fault Found:
01309 - Power Steering Control Module (J500)
004 - No Signal/Communication
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001062270624
Coding: 3F3F0B60071002
VCID: 2A51EED485E4089
1 Fault Found:
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 191
Mileage: 173392 km
Time Indication: 0
Date: 2000.00.00
Time: 21:52:18
End ---------------------------------------------------------------------
Dan
Chassis Type: 1K0
Revision: 00H13001
Coding: 0021122
1 Fault Found:
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 191
Mileage: 173392 km
Time Indication: 0
Date: 2000.00.00
Time: 21:52:18
