Old May 16th, 2012, 16:20   #1
LexKYBioTDI
TDI(s): 2003 jetta
Default How to change ignition lock cylinder?
I have been have immobilizer trouble with my 2003 Jetta. Had the keys reprogrammed. Stranded again a week later. Dealership ordered a new lock cylinder/key reader for me. Is it possible for me to replace the cylinder myself so I don't have to tow it back to the dealership? If so how do you remove the cylinder, and is there anything I need to watch out for?
Thanks.
LexKYBioTDI is offline   Reply With Quote
Old May 17th, 2012, 17:49   #2
LexKYBioTDI
TDI(s): 2003 jetta
Update.
I figured out how to remove the old ignition lock cylinder. I replaced it with the new one. Still has the same issue. Car starts but immediately shuts itself off, with key symbol flashing on the dash.
Maybe the keys need to be programmed to the new cylinder?
Old May 17th, 2012, 23:06   #3
BlownBusa
BlownBusa's Avatar
Put the key in, turn it to the run position, but don't try to start... Walk away for bout 20 minutes... Come back and start the car! Tah-Dah...
And if that doesn't work now that I think about it & yours is a 2003...
http://wiki.ross-tech.com/wiki/index..._applicable.3F
2012 Passat TDI SE+ roof/nav/fogs/DSG
2000 Jetta TDI with all the fixin's (sold to a JARHEAD)
2004 GTO goes "potato potato"
'99 Turbocharged BigBore Hayabusa 300+HP(for now)
BlownBusa is offline   Reply With Quote
Old May 21st, 2012, 14:27   #4
LexKYBioTDI
TDI(s): 2003 jetta
Update.
Had it towed back to the dealership to have the keys programmed. Didn't work. They say there is a short in the instrument cluster that won't allow the keys to be programmed. Need to change the instrument cluster.
Is this something that can be worked around with an aftermarket chip?
Old May 21st, 2012, 16:47   #5
PDJetta
PDJetta's Avatar
There is a way to simply disable the imobilizer, but I think the dealer may have to do it.
--Nate
Old May 21st, 2012, 18:04   #6
LexKYBioTDI
TDI(s): 2003 jetta
The dealership claims that the immobilizer cannot be disabled.
Old May 22nd, 2012, 01:58   #7
Jackilus
Jackilus's Avatar
Did you check the Vortex?
Blue headlights suck.
Jackilus is offline   Reply With Quote
Old May 22nd, 2012, 04:43   #8
yetimus
Thumbs up
TD Tuning will do an immobilizer delete for $120.
I've talked to you a MILLION times about your exaggerating!
yetimus is offline   Reply With Quote
replacing the ignition lock cylinder chimchim VW B5 Passat TDIs 3 November 19th, 2012 04:50
ignition switch/lock cylinder question? ivorsparks VW MKIII-A3/B4 TDIs 5 August 26th, 2010 13:52
Where to drill ignition lock cylinder to remove? ivorsparks VW MKIII-A3/B4 TDIs 3 August 5th, 2010 11:16
Bad Ignition lock cylinder ? tibbar VW MKIV-A4 TDIs (VE and PD) 2 May 17th, 2008 00:32
Not lock cylinder, ignition switch BUMMER! a808angel TDI 101 2 April 12th, 2007 20:22
Page generated in 0.15914 seconds with 11 queries
[Output: 83.62 Kb. compressed to 71.73 Kb. by saving 11.89 Kb. (14.22%)]
