Hello,
I own a 2002 Jetta tdi wagon with 375,000 on it.
Just the other day I went to start the car and nothing happened in the engine compartment. All of the lights come on as normal.
From this I proceeded to see if the solenoid on the start was functioning and it wasnt. First by feeling the starter for it and then actually measuring the solenoid signal cable voltage for 12v. I also was able to turn the care over by applying 12v to the solenoid.
My First test was the clutch switch. I shorted the switch and still nothing happened. I also test the switch for continuity and no continuity in the respected positions.
From this I moved on to check the solenoid wire. I checked it visually and with my meter by probing into the insulation and checking continuity. Checked the wire right before the wire goes into the wrapped harness.
I then went on to the ignition switch. I test for 12v at the red wire, then tested for 12v coming out of the Red/Black wire in the start position. Are there any other wires that matter to turn the car over that I should test in this switch.
I'm slightly at a loss. I've checked what seems like the major parts of this circut and followed the guide from my chilton manual and a write up on here.
Here is the Guide: http://forums.tdiclub.com/showpost.php?p=1972354&postcount=5
I also believe the chilton manual wiring diagram is oversimplifying the circuit , could someone comment on the accuracy of this diagram?
I have also read that the security system could be interrupting the start circuit. Is there any way to test this?
Any Ideas on this? Any help is appreciated
