Trans O2A Shifter Bushing Kit??
ejallison1
Kansas, Illinois
98 Jetta TDI AHU, 97 Passat TDI AAZ, 04 Golf TDI PD, 01 NB TDI ALH
Impossible to shift the 98 Jetta. Previously have replaced the shift carrier:https://www.idparts.com/shift-carrier-early-a4a3b4-p-741.html when this occurred but am thinking I will need to drop the exhaust shield and pipe and replace the bushings etc. inside.
Have never had to do this before but am wanting to just keep it stock instead of changing over to the O2J tower as I have read in researching this. Am I correct that changing out the bushings requires dropping the box out the bottom? It can not be done from the top?
I did find this kit from Uro and they said it will work on the Jetta TDI but it is listed for a MK3 VR6: http://www.urotuning.com/Shift-Bushing-Rebuild-Kit-9-pcs-Mk3 VR6-p/shifter_rebuild_kit_mk3_vr6.htm Does this look like what will be needed?
Also found this on Ebay by Uro: https://www.ebay.com/itm/Manual-Tra...h=item1a620804b4:g:ytoAAOSwbTtbmHud:rk:1:pf:0
Anything else I should consider getting before tearing into this?
lisab4
Belgium
1996 Passat B4 1.9 TDI
I did this, but ordered each part separate from my VW dealer. Worked like new afterwards! And yes, drop the box.
ToddA1
NJ 08002
'96 B4V, '97 B4 (sold), '97 Jetta (scrapped)
2nd kit is for 020. There was a recent thread where someone said it could be done from the top.
-Todd
Steve Addy
Iowa
97 Mk3
Mk3 VR6 and TDI both used 02A transmissions so the shifter components will be the same inside.
Steve
garciapiano
Southern California
1997 Jetta TDI (1Z)
One final option is to use the shifter bushings from dieselgeek. They have bushings that go inside the cable ends to remove play that accrues as the bushings age. And I’m not aware of anyone still offering those cables new.
