Old February 4th, 2018, 14:15   #1
rionzion
Default Opinions on VW 501 14 spec brake fluid...
I'm due for a brake fluid change... i have the ALH tdi (2003), brake and clutch are a shared reservoir.
my service manual states:
Permissible brake fluid specification
t Brake fluid conforming to US standard FMVSS 116 DOT 4 (previous brake fluid)
t Brake fluid conforming to VW standard, VW 501 14 (new brake fluid).
...so its saying i should use vw spec fluid for a renewal.
that said, many manufacturers, e.g. Castrol, state that their dot 4 fluid is suitable for vw's
from what i understand the VW spec fluid is low viscosity at lower temperatures.
trouble is, there arent many brands that meet the spec (Liqui moly sl6 and pentosin dot 4 LV are the only ones i can find) - and theyre about twice the price at least.
To be honest, i've decided to go with DOT 4 since its available from my usual supplier and i'm ordering a bunch of other stuff off them too, so its cheaper to get it all in one go... besides, i dont use the brakes much anyway! (joking, only joking...)
but it would be interesting to get folks opinions on this anyway, so fire away!
rionzion is offline   Reply With Quote
Old February 4th, 2018, 15:08   #2
Mongler98
ATE Gold Dot 4, Change it every 2 years regardless of miles using a vacuum brake bleeder or a pressure one. as long as air does not go into the ABS your fine and a normal change as usual.
Old February 4th, 2018, 20:20   #3
Steve Addy
TDI(s): 97 Mk3
DOT 4 is fine for brakes, I wouldn't worry about trying to obtain the VW approved specification fluid, just order the DOT 4 it from your supplier.
I have used the Castrol before, it's fine. I don't recall what other DOT 4 I've used.
Steve
97 Jetta TDI, 90 B3V TDI, 92 MB 300SD
You didn't poison the coffee, did you? Not anymore than I usually do.
Steve Addy is offline   Reply With Quote
Old February 5th, 2018, 05:32   #4
Mongler98
I only say ATE gold as its the best way to get the highest boiling point and is a very good quality brake fluid.
Old February 5th, 2018, 05:59   #5
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
The newer cars require an LV type fluid, your 2003 does not. So really any quality DOT4 fluid should be fine.
I prefer Ate or Pentosin or Textar fluid myself.
oilhammer
www.cardocautomotive.com
Old February 9th, 2018, 14:01   #6
iluvmydiesels
TDI(s): AHU
Fuel Economy: mk2's about 48mpg, mk3 ~43mpg thats @(near)80mph(-/+).
i cannt remember 100%, dot3 is older specs, i cannt remember dot4 100%, dot5 never worked out, if you can stay away from this type. i buy the valvoline, its a semi-synthetic if im told right. thereby it has less water capturing qualities, had pretty good results on my end, no real problems with it. i when brake fluid needs to be swapped out, take an ordinary kitchen type baster, yes get one at you supermarket, and draw out all fluid from reservoir, now put in fresh fluid, and bleed each brake, for fresh fluid, comes out pretty quick, keep reservoir topped off (of course), and your usually ok. do every 2 or so years. unless other brake work, happens ooh about every 40kmiles maybe more, depending.
small fleet of mk3 tdi
have exp on mk1&2, idi
other vw interests
iluvmydiesels is offline   Reply With Quote
Old February 10th, 2018, 08:14   #7
KLXD
Are not DOT 3, 4, and 5.1 all ethylene glycol based and therefore all synthetic making any claim of "synthetic" marketing hype?
Dot 5 is silly-cone. I wonders why the ell they used 5.1 for another glycol fluid.
What's LV?
Nevermind. The internet tells me it's low viscosity DOT 4 and presumably still ethylene glyol.
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
Old February 10th, 2018, 09:29   #8
Mongler98
there is only one true factor for brake fluid, thats the boiling point index for both new fluid and fluid with 5% water content. ATE as the highest i have seen but im sure there is higher.
Reality is, if you change it every 2 years, you can get away with any fluid you wish, dot3,4,5 makes no difference. We are talking race and specialty applications for most stuff. Heck in Cuba, they use shampoo for brake fluid due to the embargo.
http://safebraking.com/diy-cuban-brake-fluid-homebrew/
Old February 10th, 2018, 10:45   #9
iluvmydiesels
TDI(s): AHU
the stuff i use the valvo 'so called synthetic' is ok, its supposed to have less water absorption, that is not inclusive of a poorly maintained system, it probably has at the least some performance over 'std' brake fluid. its not really that more cost. wallymart discontinued that stuff, to economical. i go to most pep boys or perhaps an advanced and get a big qt bottle.
i realize it may be an old type of marketing hype, its at the least supposed to 'perform; better.
other vw interests
Brake Fluid Spec tdiblair Fuels & Lubricants 3 November 12th, 2011 17:39
New Brake fluid Spec Model year 06 Ol'Rattler VW MKV-A5 Golf/Jettas 2 February 22nd, 2008 12:31
VW 501 14 Brake Fluid Ol'Rattler Fuels & Lubricants 5 February 21st, 2008 22:27
Brake Fluid Spec. vacman Fuels & Lubricants 7 July 23rd, 2007 15:13
VW 500, 501, 502, 503, 505, & 506 Oil Specs SkyPup Fuels & Lubricants 29 November 2nd, 2002 00:57
Page generated in 0.12164 seconds with 11 queries
[Output: 90.73 Kb. compressed to 77.64 Kb. by saving 13.09 Kb. (14.43%)]
