So I know of these guys> http://www.etrailer.com/ but what other options are there for towing?
I guess the bigger question will be if that will work to pull what I want. I know that the ALH Golf can pull up to 2,000 lbs (200 lbs tongue weight for the linked hitch).
There is a airplane I will be looking to buy soon. It is a light experimental aircraft in parts inside the trailer. The trailer seems to be fairly basic. I am guessing it weights maybe 1,000 lbs. The plane weighs 500 lbs. The tongue weight is guestimated at 100-150 lbs. All this seems to be correct. But I wanted to run it past everyone here before I do it. I realize these weights are guesses (past the airplane that I know weighs 500 lbs), but I am thinking that they should be accurate.
What do you think?
Here is a couple pics of the trailer
Here is a pic of the trailer before it was enclosed
The trailer has lights on it, so I am guessing I will need a wiring adapter as well.
What do you think?
